- 8 Mar 2006
- Near Winchester
As above^^^
Empty or fully laden, just not over laden.
it is over laden then it shouldnt be on the road.
bullit
i have had a read of the DVLA Site which stats:
If the vehicle has a maximum authorised mass, which exceeds 3.5 tonnes, but not 7.5 tonnes then a category C1 licence is needed. If the maximum authorised mass exceeds 7.5 tonnes then a category C licence is needed.
now obviously a LWB Transit is 3.5 tonnes, does that mean i need a C1 license, or does that not class as over 3.5 tonnes?? bit confused.
I drive a 3.3 tonne Vauxhall Movano (soon to be a VW Crafter with any luck) on a standard Cat B licence (passed 2005) with no problems. As others have said, just don't go over the weight limit of the van as then the licence won't apply and the van becomes illegal.
You can drive up to an unladen 3.5t on a normal car license. I asked the traffic policeman next door to explain it to me as I just bought a 3.5t LDV.![]()
A LWB Transit is NOT 3.5 tonnes, its maximum kerb weight including payload is 3.5t.
The Licence will still apply, you would simply get done for overloading if caught.
Dureth - please can you confirm as i'm really confused about this issue
is what you say here correct even if the registered weight is over 3.5t please? @Dureth
helpful -westy-, thanks!
i came across this thread today as i am quite confused about whether the 3.5t limit on B license for those who passed after 1997 is MAM or unladen vehicle weight like @Dureth suggests
Hi Invader, i'm confused about your answer?
https://www.pistonheads.com/gassing/topic.asp?h=0&f=23&t=943817
Do you'd need to modify the suspension and possibly brakes - just take your C test.
