- 28 Aug 2003
- Portsmouth
Hi
I'm looking for a nice and quiet gaming system. I have already got an Antec SLK3000b case which has 120mm front fan and rear fan, (both of which are silent.)
I'm not too sure about the RAM/mobo combo...but i picked ASUS becuase from my previous experience their mobos are really reliable and well made. The graphics i chose because i guess its meant to be quite quiet. I would probably have chosen the cheapest 8800GT and then put a quiet cooling solution on it anyway so the Leadtek seemed ideal. I didn't want to go for the Sparkle 3 heatpipe 8800 GT because although i have experience of GFX without a fan (my 5900FX with zalman cooling solution) i would be worried about my case temps with that GFX.
I will of course be clocking the E2200 but not too extreme. Say 2.8 or 3ghz due to the voltages/temps required for higher clocks, and i've read mainly from posts in here that 3ghz is achievable with the stock cooler - which also is meant to be dam quiet too.
The HD and DVDR choices don't really bother me too much, as I think most brands/models sold here would suit me just fine, and there is little difference between different models/brands.
So does this seem like an OK setup?
Also i was wondering what are the differences between the Asus P5K and the Asus P5K PRO versions? Apparantly the RAID function on the Asus P5K is a mere RAID between a eSATA and a SATA drive....but what about on the PRO version?
looking forward to your views/comments
