Quick Dirac Notation question - (maths)
4 Jan 2005
Got a question as follows:
<aaa/aab> where the slash is meant to be a straight line down and a is alpha and b is beta. Alpha and Beta are orthogonal.
In this case can you work out the bra-ket by doing each pair, i.e aa = 1, aa = 1, ab = 0 ? Giving an answer of zero? I am not really sure. Alpha and Beta are the two states for nucleon spin.
generally any help is much appreciated.
Square
I'm not really sure I understand the problem. Firstly, a and b being orthogonal does not necessarily mean that <a | a> = 1. That would be orthonormal (if <a | b> = 0 as well.)
If |a> and |b> are states, then I'm guessing that |aab> means the tensor product of the three states |a>, |a> and |b>, for three different particles. In that case (using x to mean tensor product)
<aaa|aab> = (<a| x <a| x <a|)(|a> x |a> x |b>) = <a|a><a|a><a|b> = 0.
To make it clearer you could add suffices to the bras and kets (1,2,3 for each particle, then the 1 bras only act on the 1 kets etc.)
However, I'm not entirely sure about this.
hmmmm, it has been a good while since I've done any QM, but off the top of my head I think you can think of the ket as the column vector, (a,a,a)^T and the bra as (a*,a*,b*) where the stars denote the complex conjugates. Then <aaa|aab> is just the inner product, so equal to aa* + aa* + a*b, and a*b will be zero. Note this may not be right, so definitely best to check with someone.
that was my main question about whether the above manipulation is valid, then the problem is fine.
thanks for the help.
*snigger* :D
