ATI 3750 HDMI
28 Dec 2003
So I've procured an ATI 3650 card which will be used to drive a TV via HDMI, except there's no HDMI out on it!
Seen all the guff about these cards' ability to output both video and sound via a single HDMI connection and that sounded perfect but the card itself has two DVI connectors on and the print on the box makes mention of an "intelligent DVI to HDMI adapter", but there's no such thing in the box.
Rather narked about this tbh. Considering all the PR about this feature and HDMI output in general, I was expecting the adapter to be included. Anyone else with such a card had the relevant adapter included or know where on earth I get it from. Note they say "intelligent" as if it's not a standard DVI-HDMI adapter, presumably this refers to the way it includes the sound though god knows how this works.
An adapter should have came with your card by the sounds of it, maybe email the manufacturer or etailor to ask them to send you one ?
If you're desperate though you can buy them on auction sites for as little as £5.
As I said, I don't think it's a standard HDMI adapter as it's supposed to integrate the sound aswell so a cheapo one from a fair or auction site ain't gonna do the job.
Have emailed both the retailer and manufacturer. Unless the answer is "oops yes, we'll send one straight out, very sorry" then the car will be going back and I'll not be buying anything from that manufacturer ever again.
For reference my powercolour 3850 came with it included. I think I read someone contacted ATI themselves for one, that might be worth trying.
No was another retailer as OcUK didn't stock the particular model I wanted.
The manufacturer's website shows five accessories and three of them are there but both the DVI dongle and HDMI adapter are missing. Have emailed both the retailer and manufacturer so will see what they say.
EDIT: Well just had a look around and found a couple of reviews of 3650 cards from this manufacturer and none of them came with the HDMI adapter but did have the DVI dongle. This prompted me to recheck the box and, sure enough, the DVI dongle is in there, it had just slidden out of view so I didn't spot it initially.
This basically means that it was never intended to come with the HDMI adapter which is really annoying as I'll now have to source one. Whilst tempting to just get a cheapy one from somewhere I don't know how this sound-over-HDMI is supposed to work and whether I need a special adapter to support it. Manufacturer is still getting a stinking email about deliberately vague marketing material!
this is the dvi to hdmi dongly you should have recieved, i got one with my 2900xt...
All you have to do is plug in a hdmi cable into it.. and into a tv.. and magically sound will appear!
good luck
Then how come the ATI cards only have DVI on most and all have Azelia audio chips on board?
That would be a bit silly, do you not think?
Does anyone know how the sound over HDMI functionality actually works? Does the card use some spare pins on the DVI connector to output the sound?
I'd happily buy the adapter separately but it's obviously not a "standard" one and I don't know what to look for.
only the HD series have audio onboard and most come with the adapter..
im 99% sure it uses separate pins in the dvi connecter that why you can't just buy any adapter...
i would say email ati or call them and they'll send you one. maybe for free if you be nice.. :D
Cast your eyes over my thread here
Long and the short?
Yes, you need the DVI-HDMI adapter from ATi as it is a no standard pin configuration inside the adapter.
You then may or may not get sound - some people are lucky and it works - other (like me) aren't - it's all in the thread! :mad:
Well it's going back as I've had enough of Powercolor. They skimp by omitting the adapter in the first place and then can't be bothered to respond to any support inquiries - avoid them like the plague, they're cheap for a reason.
As for ATI, well they're just as laughable. Whilst they've responded to my support enquiry, take a look at the drivel they've posted:
In order to enable HDMI support on the Radeon™ HD 2000 and 3000 series board through the DVI connector, AMD has designed a unique DVI-HDMI adapter that is only available through certified vendor(s) selected by AMD to authorized partners.
The Online Shop ATI is offering the DVI-HDMI adapter (Part Number: 6141054300G) as a replacement to lost or damaged adapters ONLY. It can not be sold separately. This adapter will not enable HDMI through the DVI output of any Radeon™ HD 2000 and 3000 series board; it will only work if your product was originally shipped with a DVI-HDMI adapter.
So they claim that the replacement adapter will only work if you had one to start with and if, like me, you weren't supplied with one then the replacement won't work. Err, wtf!?
"This card supports sound over dvi/hdmi"
- To achieve this you require the ATi supplied dongle, which we haven't included
- ATi does not sell said dongle unless it originally came with the product.
So, basically, you've been sold a tin of sardines without the key, and are not allowed to buy it yourself.
"We promised you sardines, you own sardines... what's the problem?... oh, you want to eat them not look at the tin?... weeeeeeell I don't know about that! That'll never catch on!"
Does kind of make you wonder when the company claims the card is capable of a function, but ATi claim it isn't and won't sell you the bit you need to make it work - I smell another large class action lawsuit brewing ;)
That is pretty bad support from ATI/powercolour guess I wont go near em either, perhaps sapphire will stock it.
Edit just found this:
ATI DVI DVI-D Male to HDMI Female Adapter Converter
(run that search on fleabay !)
Connects a DVI-D or DVI-I digital display to a device with an HDMI display output
Allows HDMI Type A cables to be connected to a device with a DVI-D or DVI-I input
Supports Digital Video and 5.1 Surrond sound Audio signal
Connectors: HDMI Type A Female to DVI-D Dual Link Male
Supports ATI Radeon HD 3xxx Series & Radeon HD 2xxx Series Models from:
Apollo ASUS ATI Connect3D Dell Diamond Gateway GECUBE GIGABYTE HIS
HP IBM Jetway Lenovo MEDION MSI PowerColor Sapphire SONY VisionTek
in Stock! Ship Worldwide Immediately!
any good?
Man theres like 3 threads in the same row :
HD2400 Pro/XT Audio-over-HDMI: A tale of disappointment!
cavemanoc 15th Feb 2008 02:15 PM
by bledd. 24 575
ATI 3750 HDMI
Vertigo1 15th Feb 2008 02:14 PM
by Vertigo1 18 434
HIS 3650 come with HDMI adapter?
Anyhow long as its sorted :)
