Lol I get where I misread it actually - tbh I don't understand how to use the link and do it. My maths skills suck.
For the first one, put:
A=3
B=11
C=-6
D=-8
and press enter.
A=3
B=11
C=-6
D=-8
and press enter.
Get ya.
Wouldn't have a clue how to write out by hand though. I just assumed that there was one single x number and the roots made it expand ie. 3x(cubed) = 9x.
Get ya.
Only way to do it by hand is to spot a root and then solve the remaining quadratic. That can be done normally by staring at it or worse case:
x = (-b +/- sqrt(b^2 - 4*a*c)) / 2a
Here the root to spot is x = 1, which is easy to check, 3 + 11 - 6 - 8 = 0, etc.
The only time that this has been useful in my life was A Level maths, then they were rigged with easy roots.
Ever since I've used the mode on my calculator which is done with clever numerical analysis
Ok so im trying to help out a mate whos had a really stressful week, can someone solve these two maths puzzles for me
3x 3 + 11x 2 -6x -8 =0
2x 3 +13x 2 -24x +9=0
The little 3 and 2 are squared and cubed.
Please help!
Fanks
ah k.
I'll edit this once I've typed it out.
Long division
I'll also type up an easier way to do it.
btw.
http://www.mathsnetalevel.com/module.php?ref=C2
login : feb
pass : feb
Do the 2 long divisions, then do the two "avoiding long divisions"
The juggling way goes like this:
3x^3 +11x^2 -6x-8 =0
(x-1)(ax^2 + bx + c) = above function. = 0
x^3 : 3 = a
x^2 : 11= b-a -> b = 14
x: -6 = -b + c -> c= 8
so,
(x-1)(3x^2 + 14x + 8)
What you do is equate the coefficients of the function and the divided function to find what the as, bs and cs are. Need any help ask more.
This is the easiest way, and is what geuben has done on his scanned version, which might be clearer - typing is pretty confusing andhard with maths :/
She said to say
You are an absolute angel you dont know how happy you have just made me xxxx
(I fink that means fanks!)
...and i posted first.Awww all the effort (ok it wasn't that much) and I didn't get recognition...and i posted first.
ah k.
Long division
