What's a good Blue-Ray/HD-DVD film to stress a HTPC?
9 Aug 2003
Liverpool
I've finished building my HTPC around the Abit AN-M2HD motherboard and a Athlon BE-2400 with the LG Blue-Ray/HD combo drive. At the moment it's running at 720p on my 32" JVC LCD and playing Planet Earth on Blue-Ray is perfectly smooth, however I need to make sure that the on-board GFX will take enough off the CPU so I ideally need a film that has a really high bit-rate or a CPU intensive codec to really test it. Any recommendations?
Have you tried outputting the resolution at 1920x1080 & let the telly downscale instead of outputting at near enough the tellys resolution.:confused:
Basically you just want a film encoded using AVC/MPEG 4 that also has a high bit rate. Such films would be:
POTC: DMC/AWE
Apocalypto (as mentioned)
Transformers
Hope that helps...
POTC: DMC/AWE
Transformers
Hope that helps...
Is there any difference between Transformers between HD-DVD or Blue-Ray?
