- 18 Oct 2002
- Stone, Staffordshire
They will use as much CPU as is spare!
Just to note that although I have a 4 port card the camwizrd software can only capture 1 input at a time.
There are other software such as the PICO software that can do 4 at once but this wasn't a requirement for me.
As I say it struggled on an 800Mhz Athlon and is rock steady on a P4 2.8Ghz so somewhere in between would be the minimum I would guess.
The capture cards also tend to be limited to 25-30fps which is shared between the inputs so if you're capturing 2 then 15fps max on each channel
