So in preperation for R-Fest in may (R32oc trip to the ring, so far about 40 r32's signed up), here is my Before ring service
New oil filter
New fuel filter
New coil packs
New Spark plugs
New MAF x2
New front + rear discs and pads
new VWMS Upper strut bearings
H&R front and rear race arb's (probably only fit the rear to help reduce understeer)
whole new bushing set
Complete engine flush with all new oil.
Clean intake port and throttle body with realignment
That is the pre-lim list as a Definite. The below list is what hopefully will be done before i go but isnt definite.
New wheels + tyres (keeping the oz's as spares)
Front end respray (yes yes, its been a while coming i know) aswell as all over touch up on whatever is needed.
Custom-Code stage 2 map to accomodate the decat pipe
And some of that protective film for when the bodywork has been done.
Dont think ive missed anything, other than the obvious bits that if anything is needed it will be done.
New oil filter
New fuel filter
New coil packs
New Spark plugs
New MAF x2
