Prassi ONES - it is the best buring suite I have come across...![]()
Can I ask why you don't want free software?
TrUz
use imgburn
free and its tiny
why would u say its better than them ?
Because I have used it extensively for sometime, it is the burning suite that I use currently, and I have not come across a better one.
There are a few decent freeware utilities that are certainly worth using:
1) IMGBurn (as already mentioned, also one of the best freeware utilities around)
2) FinalBurner (Free)
3) InfraRecorder
4) CDBurnerXP Pro
5) Express Burn
Sometimes there'll be something that is wanted which is only present in a paid for version. But if you look at all types of applications there's always a free and/or open source option out there which will do the job in hand as well as, or almost as well as similar paid for versions.
E.g.
Open Office, ccleaner, antivir etc etc
....so is it worth paying or go free?....
