Stupid of MS none the less.There's no way of knowing if this particular console was manufactured before or after Microsoft identified the problems with the machines.
MS really need to release a new range of 360's that are silent and do not die!
It doesn't change the fact that it is very unreliable.I don't know why MS insist on having the Xbox360's on show. They should just have them out of view so that if they RRoD no one would know.
*don't hotlink!*Microsofts newest range are a lot more reliable and rumours are that the Valhalla range (the ones coming out next) are as good as silent because the GPU and VGU are lower nm with better motherboard and airflow design.
It doesn't change the fact that it is very unreliable.![]()
Earlier this month SquareTrade, a firm specialising in selling electronic warranties, claimed the failure rate of the Xbox 360 was up at 16.4 per cent.
Last summer Microsoft posted heavy losses in its Xbox division after setting aside a massive USD 1 billion to tackle Xbox 360 repairs.
And to top it all off, Eurogamer had three of its staffers suffer Xbox 360 breakdowns within the last month.
I just can't help but question, with the amount the failures are costing MS, why the hell have they not sorted it? Surely small changes to cooling, etc, will be a lot less costly than replacing/fixing all these broken consoles?
It just makes no sense to me.
