Few Shots of The golf after being highly Cleaned this weekend
how hard is it to use an electric buffer?
takes a lot of practise, you can burn straight thru the paintwork in seconds LOL
They are not cheap, here a good starter one i would recommend
http://www.gpwizard.co.uk/shop/index.php?main_page=product_info&products_id=219
something like i suggested is a little more forgiving and easier to practise that will remove swirls no problem and bring the paintwork alive back to showroom condtion more or less. There has been a few posts before about detailing on this forum and people using PC's and what they are capable of doing.
some good kits on cleanyourcar aswell i would recommend something like
Menzerna RD3.02
Menzerna 85RD
Lake Country CCS Light Cut Pads
Lake Country CCS Polishing Pads
and Poorboys Super Thick & Plush Towel
p.s. get some Autoglym Metal Polish for that exhaust LOL
After a bit of practise you should be looking at getting results like this;
Menzerna RD3.02
Menzerna 85RD
thats coming off soon lol
mmmm not really that i am aware of to be honest to rent but to pay someone to do a detail for you with a pc and the correct compounds you are talking about some serious coinage a lot more than 129.99 if you serious about it i would look into it. As above you can see what a PC can do with practise and you got RED car best colour personally.
And set aside a good 8 - 10hrs to do the job lol
Dont you know anyone who got one, that how i get mine done pay in pints.
cant think of anyone with one. although my mates dad owns a body shop. sure they will have one.
i havent seen a before and after pic of what they can do. but have looked only for detailing cant really find a guide like thing
stealth edit, ill post some pictures up now give me 5 mins of before and after with PC's and claying etc
Ok found something you might like.
Wheels cleaned with AG wheel cleaner, Strong TFR mix for body and pressure rinsed, AG Shampoo, then Clay which brought up some dirt
The Bumper was scratched to bits,
And then Megs #7 glaze. The light was good at this point these are before the collinite but it was still looking pretty good at this point.
Then 1 layer of collinite 476s
Now this guy does regular details on my MG TF forum now i know he charges around £140 for Paint Correction / Machine Polishing and about £300 for the Paint Protection Detail but he mainly does Exotic cars
before anyone says No im not saying the TF is exotic he does it as favours for the forum :p
Here are few shots on a car that i know which was machine polished off my forum.
After
But this car only had light swirls to begin with so
