Wildlife, Motorsport and Aircraft.Looks good, has it been bought for any particular use/subject in mind?
Bought if from a chap on e-bay; hardly used, perfect condition for £900.where did you get it from SDK in the end?
and the 1.4?
how come you didn’t go for the 2.0? one...
is there much difference between the two?
That looks like quite a beast! It looks as if it could be very front heavy, is this the case?
I can't wait to see the sample shots from it. Is there any chance you could maybe write up a comparison between it and the 100-400?
It sure ishows the image quality? is it constant f/2.8 throughout the zoom range?
It's very balanced; the front element is massive but the lens is weighty in the middle and at the back. Its total weight is 2.7kg; twice as heavy as the 100-400L.That looks like quite a beast! It looks as if it could be very front heavy, is this the case?
if only it had Image stabilisation eh?
Ignore the colours because the camera metered the scenes differently.The colours on the 100-400 seem better to me there is more detail in the wood and less noise but that is down to the crop i reckon
F4 shot addedLooks good! If you get bored can you do one at f/4 for me?
