As the title says ...I bought a 8800GT not long ago, is it worth trying to send it back and getting a 9600gt?
Thanks.
Thanks for the reply
You see, I never understand why they bring a new series out which makes it sound like it's going to be a better card, when it's actually not? :S
Thanks.
Some benchies show it better than the 256MB 8800GT
But 9000-series, mid-range is looking very good compared to 8000-series![]()
Smaller BUS less SP. Just look at the specs!![]()
256mb is a limiting factor. Its also 50mhz faster core than the 8800GT so it will could pull slightly ahead in games that are not as much shader intensive.
Its got a 256bit bus.
well if people who name the cards were logical, it would mean that the 9600 should be faster than the 8800 ULTRA, also, the slowest cards in the 8 range, should be faster then 7 etc...
but they dont name things properly
No they shouldn't.
They are split into 3 categories, the 200/300/400's are always low end parts, so a new generation of a low end part WILL NOT compete a last generation high end part because, well, its just not meant to.
The 500/600 series are always mid range, and again are not made to compete with high end parts, just offer great performance for your money and to be better than the last generation mid range.
The 800/900 Series are the high end parts and the new generation ones will be better than any previous card out.
So basically a 9600GT is designed to better the mid range sector and has nothing to do with the high end at all.
here is a simple version of what i was saying
1,2,3,4,5,6,7,8,9,10 .. Nvidia make 10 cards in order and number them, why is card 8 better then 9?
not that im confused by the situation, but if you ask people in PC world who want to buy they have no idea, and they would 100% think 9600 is better then 8800 by around 800 points!!!
