I've been weighing up whether or not to get a Blu-ray player now that the format war is all but over and the PS3 is tempting me since the cost be all that far off getting a new drive and graphics card when all's said and done, plus I'll have a console into the bargain. I've been having a play with someone else's on their Samsung SM-2032BW via a HDMI-DVI cable and it looks great, no problems at all apart from having to dismiss a little box when you switch it on saying that the resolution is higher than the monitor can manage so it's presumably scaled down a little bit rather than chopping bits off the edges since everything looks as it should.
Before going out and getting one myself I thought I'd borrow it and make sure there were no problems with my monitor and it's a good job I did, because all I get is a black screen and an 'out of range signal' error. Is there anything I'm missing here or can a 2007wfp just not do anything beyond 720p for HD resolutions? I'll be pretty frustrated if so, especially since I'd be more than willing to go out and buy a bigger monitor if there was anything around below the 30" Dell (WAY out of my size and budget limits) with an S-IPS screen.
Cheers
Cheers
