- 24 Oct 2002
- Portsmouth
Hi all
I have a AC7 Pro right now on a Q6600. The temps are ridiculous, as high as 80 degrees when only at 3.4gig and 1.35v. It was worse before I lapped the CPU and HSF, then it was 90 degrees.
There are only two heatsink and fans I really see recommended on here and thats the AC7 Pro and the Thermalright Ultra-120 Extreme. However I'm REALLY struggling with justifying the expense of the Thermalright. It comes to almost £65 by the time you include the cost of the lapping kit that will need to be used on it's less than flat surface
£65 is a LOT of money.
Is there no other cooler that is recommended but better than the AC7 Pro, preferrably one that has a mounting system that does NOT use those cr@p push pins. I don't trust them at all. I want something that is quiet and uses a backing plate on the back of the motherboard so I know it's creating the proper pressure on the CPU without bending the board, or suffering from being less than secure
Any suggesions people? I need some help here. Or can the excessive price of the Thermalright AIR cooler be justified?
Cheers
Cheers
