Our lowest price yet - 2GB OCZ PC2-6400 CAS4 800MHz Kits @ ONLY £20.49+VAT(£24.08Inc)
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We've gone even lower and this is just getting silly now but it makes OcUK the cheapest in the UK by a huge percentage, check this out:-
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
OCZ PC2-6400 Platinum Revision 2 is the latest version of the Platinum DDR2-800 Series. The PC2-6400 Platinum Rev. 2 has been re-engineered to turn out heart-pounding 4-4-4 timings with flawless performance and stability and offer lower latencies than standard 800MHz DDR2 memory.
OCZ exclusively developed these modules for the extreme gamer and overclocker to give high-end DDR2 based systems that extra performance edge that is demanded by today’s hard core gamers and enthusiasts.
The new OCZ PC2-6400 Platinum Rev. 2 utilizes the latest OCZ heatspreader design. XTC (Xtreme Thermal Convection) Heatspreaders allow increased ventilation and heat dissipation due to an innovative honeycomb design providing more direct access to the actual memory ICs.
As part of the award winning OCZ Platinum DDR2 series, the PC2-6400 Platinum Rev. 2 is built with leading edge technology designed and qualified with special selection of premium components to maximize performance in even the most demanding computing environments. OCZ PC2-6400 products are 100% hand-tested to ensure compliance with stringent quality standards. In addition, each member of the OCZ Platinum family is backed by an industry-leading lifetime warranty, toll-free technical support and the exclusive EVP (Extended Voltage Protection) coverage.
With its ultra-fast performance, high quality and reliability, the OCZ PC2-6400 Platinum Revision 2 edition is a perfect memory upgrade for the latest CPU arrivials.
- 800MHz DDR2
- CL 4-4-4-15 (CAS-TRCD-TRP-TRAS)
- Platinum Mirrored XTC* Heatspreader
- OCZ Lifetime Warranty
- 1.9-2.0 Volts
- 240 Pin DIMM
- OCZ Enhanced Latency Technology
- 2.2V EVP**
Price: £20.49+VAT (£24.08 Inc. VAT)
BUY NOW!!
If i bought two of these instead of one more kit of Geil ULL 6400, would i see any performance or overclocking potential over it ?
But he actually did RTM which is a little uncalled for, he only had to say he did LOL
Unless he's actually that dumb to think the account had been hacked :p
this hacker is good, he's got two don's paswords....
this just cant be corect, he has even edited on the OCUK website...
he is good
