Hi,
I have recently built a new computer, (see sig below for details).
I have had real issues with using VLC media player for watching videos, because loads of these orange vertical lines appear, slightly fuzzy, and appear to shimmer slightly left and right, and then the pc crashes, and the screen then goes blank. I then have to either push the reset button, or completely turn off then on again.
I don't know whether this is an issue with VLC player and Vista, as the rest of the PC seems to be running fine. I have run Prime95 for several hours OK. I have also reinstalled Vista as I thought that my installation may be slightly dodgy.I also found that I would get these orange lines sooner in VLC media player, when I had my Creative X-Fi fitted. At the moment I have removed it to try and increase the stability.
I have this 1 yr old BFG 8800 GTS 640 MB which I am ultimatly looking at replacing as soon as I have the money, and the latest 9800 comes out. But nonetheless, I don't want to have to ditch what was a £300 graphics card. It currently runs at idle at a toasty 60C, but I gather that this is pretty normal.
Anyone have any thoughts as to what the problem could be? Or whether you have had similar problems?
Cheers,
Matt
Cheers,
Matt
