- 4 Jun 2007
- South Wales
1280x1024 with full detail, except sync every frame i get ~120fps with sync every frame ~90fps
for that setting, 1680x1050, aa on max, all eye cand and glow on, all texture settings on max should be a shoe in, im unsure about your native res as ive never played at that res but at the res i stated you should have no problems atall. i force aa x16Q in the drivers and it still plays flawlassly.
 but it seems to be struggling even OC'ed to 3.2ghz.
 but it seems to be struggling even OC'ed to 3.2ghz.snip
the amount of times you hit someone is calculated by the server..?
lets explain the concept of reg...
The amount of times you hit an enemy is calculated by you, and both a good internet connection and a good processors (be it gpu or cpu) would be needed to send this information to the server.
So a bad gfx card and a bad cpu that are being focused on making things look nice will mean that less of the cpu/gpu is doing the calculating in hits/contact therefore incomplete packets are sent to the servers resulting to the servers reporting back that you have missed them.
There is a point however, where the calculating gfx and calculating information is handled both well by top end hardware.
Not sure with cod4, but ragdolls in css are calculated by the user not the server, so you may see someone in a slightly different place to how the server see's it.
So... this means that maybe you can hit more things with a better card on a lower spec, but it will not make you jump higher than anyone else, unless its an illusion on your side.
ive found the worsed thing for me to ramp up is anisotropic filtering do you have that up high on the slider rite to its right? ive also found it has the least impact on visuals for me, its the differance between choppy and smooth in my case!
 ) and most of them had the usual, stock settings and quite high detail in the eye candy sector.  Nothing compared to what your describing.  So in terms, no, not all the top players do this at all.
) and most of them had the usual, stock settings and quite high detail in the eye candy sector.  Nothing compared to what your describing.  So in terms, no, not all the top players do this at all. )
) ) this isnt a lan or tournement setting.people keep adding things to the mix that arnt there.if people dont like my grammer haha i dont care
) this isnt a lan or tournement setting.people keep adding things to the mix that arnt there.if people dont like my grammer haha i dont care  this is a forum im not submitting for my exams.some people can actually decifer my humour cause they dont take my posts to seriously.
 this is a forum im not submitting for my exams.some people can actually decifer my humour cause they dont take my posts to seriously.I know of many gamers that WILL play on lcd's and high res's.BUT i also know just as many who dislike lcd's and have always felt better playing at a res like 800x600 or just above.Not everyone likes wide screens or a lcd for that matter.I cant see what the problem is if he plays at a low res or uncaps his fps.If you game a lot even if you don't use it your try it just to see , its a tweak easy done not even a console cmd just lower settings.Get of his back already.
I prefer CRT screens to LCD's, but dont have one because they are huge. The thing is, it's stupid buying high end hardware to play at 800x600 all low settings to get 333fps so you do all sorts of extra crap or jump higher or something having an unfair advantage over other people and you know it.
