Best Anti-Spyware app for Windows Vista64?
Caporegime
3 Jan 2006
Chadderton, Oldham
What is the best Anti-Spyware app to use in Windows Vista64? I tried Super Antispyware but that just pops up at boot and gets on my nerves and Ad-Aware-SE just does not work, stops scanning after a certain amount :\
Thanks.
Willz.
What AV do you have? NOD32 has both AV & Antispyware, so might be worth a look.
Adaware usually finds loads of minor cookies that internet sites use for browsing that's why... rarely anything useful. Did you try configuring Defender more in-depth?
Yup, on its own. If not then all I can suggest is doing some more research and Googling different apps that appear to be 64-bit compatible... that's all i'm doing. :)
I use Avast AV with Spywareblaster 4 ,Spybot 1.5.2.......I set Windows Defender to do a real scan once a week,with these and my Vista firewall and hardware firewall router never had any problems.
are all these free downloads, and i didnt think avg had an anti virus for vista64?? please correct me if im wrong:confused:
Yes they are all free,AVG,AVAST,AVIRA all have free anti-virus programs for Vista x64,take your pick on choice.
I also forgot to say I keep UAC enabled too,so I have pretty good security.
