Caporegime
- 8 Jul 2003
- In a house
Just found these over at Laptopvideo2go, for 6/7/8/9 series cards.
XP 32bit
http://www.laptopvideo2go.com/forum/index.php?showtopic=17739
Note: Once downloaded and extracted, the extracted Folder will be called:- 174.31_vista64, but they are XP 32bit.
XP 64bit
http://www.laptopvideo2go.com/forum/index.php?showtopic=17741
Vista 32bit
http://www.laptopvideo2go.com/forum/index.php?showtopic=17737
Vista 64bit
http://www.laptopvideo2go.com/forum/index.php?showtopic=17740
Enjoy.
EDIT: Also download the modded.inf's for the set you require, then once you have extracted the drivers, drag the modded .inf across into the extracted folder thats created, and say yes to replace, then run the Setup.exe to install.
XP 32bit
XP 64bit
Vista 32bit
Vista 64bit
Enjoy.
I shall be installing these after dinner
