Lemmings - Remake - [ Duh its lemmings! )
Caporegime
8 Sep 2006
On Ocuk
From the developer
You have probably seen my blitz lemmings thats floating about on the net, the ten level demo, well i decided to make it the full working version. It includes all the orig levels and ohno more lemmings levels.
http://homepage.ntlworld.com/geoffrey.storey/Lemms.zip
From here
http://www.retroremakes.com/forum2/showthread.php?t=10878
Totally crashed on "loading"...
Doesn't crash i left it for ages and it worked but this is hopefully being fixed..
It takes upto a min and just over to load the first level , then its 5 secs for the next three then 40secs for the one after.. FAR too long :o
I just had to restart my PC it took so long. :(
Weird about the loading times. I've just been playing it on my housemate's horribly bug-filled laptop, and it loads the levels very quickly. Ran fine too, until it crashed on the sixth (or so) level with a memory access violation.
As long as it doesn't keep doing that, top stuff.
I would love to see a remake of Lemmings 2, the Tribes!
no i never liked that one. I think lemmings was a one off and a sequel didn't really work too well.
I used to have a windows version of lemmings with oh no more aswell. It would run in a window and you could choose any level or play through them, it even saved automatically. Can't remember where i got it from though.
Restart pc...
Strange , ctrl alt del and or alt tab worked for me as i thought it crashed too first time round :D
Yeah that worked first time round, but 2nd time ctrl alt del didn't work for me. Just got stuck on the loading screen. Downloading the updated version now to try that out.
