To attempt a front flip start off by just doing hand-stand and then go all the way over with your back arched so you land on your feet.
I would say a backwards flip is easier to practice. You're more likely to be able to catch yourself if you get it wrong.
but its how do i practice i mean the technique must be a huge part in it.
Just don't be afraid to fall, cause if you are then you'll hesitate to swing your arms lose momentum and fall, which is what will generally happen the first 5 times till you figure out it's not that bad.
"Don't land on your neck"
gym mats, and don't worry your neck is surprisingly strong.![]()
on your head be it when it goes wrong
well actually it will be on his head but you know what I mean![]()
Well I used to do gymnastics quite a lot, Unless you land really awkwardly, or with your neck/body twisting, the worst you end up with is a bit of tender/stiff neck for a while.
