Hey Guys.
I bought an item from the USA and it arrived last night.
It's a stand for my iMac, which also houses an 4x USB hub.
Simple enough, but the power adapter is for USA, obvisously.
What I would like to know is, if I use this adapter I have here will it work.
Basically I got one of them plugs which you can change the voltage on, and comes with different plugs on the end depending what you need.
Well it has one for this Hub, and on the hub itself it displays a 5V sticker.
Will all this be ok to use, changing the adapter plug to 5?
Cheers for any advice!
