Saying it is 512bit is wrong?
No?
Yep, it's wrong if it's 256 bit x2.
Are we 100% sure thats its 2 x 256Bit or is there a chance it could be 512 Bit x 2
Just so many people say its this and that and as yet no hard facts![]()
what brings you to that conclusion, just because they put two GPUs on the same PCB doesn't make it any more of an engineering masterpiece than two PCBs together,
there not 100% sure, just guessing i assume since as far as i know the technical data hasn't been released for these cards yet, there still under NDA right? and too all the 'X2 is technically better' crap, what brings you to that conclusion, just because they put two GPUs on the same PCB doesn't make it any more of an engineering masterpiece than two PCBs together, at the end of the day its the exact same thing just executed differently, i would be willing to bet good money that if they wanted to NVIDIA could make a dual-GPU, one PCB 8800 series card, but why bother, whats easier developing an entirely new PCB layout and heatsink from scratch or just bolting two existing PCBs together and doing it that way![]()
Trouble is maybe they used double density chips, or more could be mounted on the back. Not forgetting that a 256bit or 512bit card can use 512Mb of vram. I'd say its 256bit because its a G92 with 16 ROP's 4x64bit channels, going by their architecture 512bit would be 32 ROP's 8x64bit.If anyone wants to correct my maths, feel free.![]()
Upgrading is a waste of cash..correct ?
3dFX did it in 1998 with the Vodoo not 2000 so were before ATI.
Either way the comments about "Feats of Engineering" etc dont seem to mean much as I would buy neither of these cards.
Who really gives a monkeys about who did it first, the fact is if we all had cash to burn, we'd probably buy one for sh*** and giggles anyway...
It looks sexy as hell and is probably powerful enough to run anything we can throw at it.
I can use Maze 5 blocks on ATI cards that i know of from 1800xt upto the 3870x2 & what a cost saving.Im curious as to why some think it's important as to which implementation is the best or correct way of doing it from a technical point of view
Surely once you've installed the card in your rig, the only factor you'd be interested in is the performance, not what it looks like or how the cards been designed/built etc
I can see why things like sound and heat are important to some, and I understand the width of the cards are also important in terms of single/dual slot design and space within your case but all talk about ATI 2 cores on one PCB as opposed to Nvidia 2 cards welded together..........why is it relevant ?
