water cooling for truely silent system?
7 Jan 2007
Sussex, UK
lo,
never looked into/built a WC system. Just wondering what components I would need and a rough price?
I don't have anything over clocked, just after ultra silence.
Q6600 G0
P35_DS3R
8800GT
Any suggestions? Ideally i dont want any case fans, just water cooled stuff.
Water cooling uses fans to cool the water, if your not overclocking just buy some quiet fans for your cpu/case etc.
Loudest thing in a W/C setup would be the pump.
I have 3 fans cooling my radiator and they're silent, but the pump can be heard at night which irritates me! Only slightly though, I'm just picky
See log in sig for 0db project - but a Q6600(B3)/x975/7800gt at stock was very toastie. (70c at 75% load)
with a quad and 8800gt I'd recomend two passive loops (overly expensive) or better still fans with 7v mod
Maybe your pump is defective, I have to lok for waterflow to know my Eheim is on.
Or maybe the pump is making the case resonate?
If you want a passive watercooling setup of a Quad Core, mobo and 8800GT you need a very large radiator and I mean VERY large.
I don't think its possible to make a system that is 0db even with water cooling.
Very difficult, pumps can be very quiet but another issue can be the PSU, there are passive PSU's but they usually have a low output and/or are external PSU's and even then they can produce 'electrical noise'
0db over ambient is possible in any urban/suburban environment (even at night)
There’s at least 4 members here with such systems that I know of - myself included. In general we all have only one fan (>900rpm either in the psu or on a rad) that isn't mounted to the case
At stock it's really easy with quality efficient parts and air-cooling.
If OCing you need more planning and larger budget for a passive water system.
But 0db in as isolation chamber would be near imposable agreed - but that only theoretic.
Edit - personally my submerged 3w pump is inauabable - it's the hdd that make the most noise when seaking. I don't have the budget, but you could used solid state ones.
