9800gtx pic
What's that LED thing for right next to the exhause grille?
I've just looked up that memory, it's GDDR4 with a speed of anywhere between 0.7ns and 0.9ns depending on which specific chip it is. It's also packaged as 16Mx32 which, if I'm not mistaken, means the eight chips on the board gives you 512MB.
K4J52324QE-BJ08 > GDDR3, 512M(32ms), x32, 8 Bank, 1.8v, 0.83ns
512M = 16Mx32 , so 64MB modules, 16 million address' 32bits wide.
No memory on the back so 512MB, same stuff as the Ultra btw, rated at 1200MHz.
Yup, supposodly their 1teraflop card that was meant to come on nov was the gx2, coming up on 4 months late. =/
The link of the pic is lost. Could you post it again?
I'm also very confused by nVidia. Regarding to all the reviews I could find on net, the 98GTX is not better than a G92 88GTS but more expensive. I can't even assure if it is 128 pipes or just 112 pipes like GT. Very disappointed.
Any truth in this?
http://www.fudzilla.com/index.php?option=com_content&task=view&id=6125&Itemid=65
Nvidia's refurbished G92-based 9800 GTX will launch in the last week of March. The card will cost €399 and it will have 768MB of memory.
It will also have two SLI bridges and it will support Tri SLI. The quad SLI will remain the thing for 9800 GX2 cards and you won’t be able to use more than four chips at the same time.
The last one to complete the Geforce 9 high-end to performance line up is 9800GTS, but we don’t know when that should launch. It should probably launch a bit later.
Can't see how it can have 768MB mem using a 256bit bus...
EDIT - Also here is GPU-Z of GTX, 512MB :: HERE
Yeah is a bit strange with the 256bit bus, could be a typo, he could have put 768mb as its called a GTX, and the 8800 GTX has 768mb, but this is just a slightly overclocked 8800 GTS 512mb with the first 8 changed to a 9 in its numbering.
