At the moment I have my logitech speakers hooked up to my PC and my 360 plugged into the AUX on my stereo. I would like to make some room though by ditching the stereo and using the logitechs for both the PC and the 360 but I'm just not sure on the best way of doing this.
The logitech speakers just have a 3.5mm connector so I tried the following:
Speakers 3.5mm -> 3.5mm coupler -> 3.5mm 2-way splitter
One side of the splitter into a 3.5mm to phono adapter -> 360 VGA phono cables.
Other side of splitter into 3.5mm cable -> PC sound card
This works in that I get sound through both the PC and 360 at the same time but the quality is very poor with an audible hissing sound.
So, is there a better and easier way of doing this or should I simply use better quality cables? (Belkin coupler, HAMA 3.5mm to phono cable, no-name splitter).
The other option is an amp but I can't really afford that right now.
