/Sorry for the hijack Jokester.
To be honest, I don't look at the temperatures as reported by software much mainly because the diodes are extremely inaccurate with sub zero temperatures. This E8200 reports idle 32c in bios and one core at 42c in windows using coretemp, hot CPU? Not when the condensor on my phase is reading -60c. The hotest it will get with the E8200 clocked and silly voltage through it is -53c. The QX9650 clocked with silly voltage would get to -43ci ish. The P4 520 would be -36c clocked. These temperatures are more for me to gauge how my unit handles the load its under, but it also gives me a rough idea of the heat output of the CPU. So when a Wolfdale at idle doesn't even stress things 1c. I can safely say that it is not putting out the sort of heat a temperature reading of 40c would suggest.
I don't see how an E8500 (ES) can report temperatures that seem to be believable but the E8200 retail is completely out! I have seen another E8500 with the temperature readings waay out. Faulty diodes or the need for Bios updates? I don't know but I won't trust any software readings for Wolfdales.
If you can read the temperature in your CPU socket on the motherboard; take an educated guess from that.
