13768 a good score for a single 8800GT?
LOL!
I had 9000 out of my GT at stock, and the oced my CPU and GPU as in sig and got just over 12000, so Id be very happy with 13768
My clocks are 702/999
LOL!
My cocks are 702/999
Quoting before you edit, because I lol'd at that. But I guess I'm immature. :D
And yes, that is a good score. I hit 12.3K with my rig.
The result you are trying to view could not be found. !
Strange worked for me. It maybe because I aren't registered with them. So here's a screen shot.:)
I got one extra point when I did the test again. O.O amazing. lol
I get 13705 with [email protected] but now my CPU is at 3.3 and ram at 976 so I'm about to rerun my score with single 8800GT @ 700-1700-950 and see what happens!
Do you have a compare link to yours ?
Erect and normal? :p
Why would you say that? :( you're making people get bad mental images :D
To think my PC was intended to be a media centre PC that's why it's all inside an Antec Fusion case but it ended up a Gaming rig again. I just can't help it.
You can almost play Crysis :D Are you using Water cooling? I'm just using air. :(
Air ;) I've got about 1.66v going through my quad though. I'm using a thermalright 120 extreme HSF on it, so it's not too bad :D
Crysis 1.2 patch has came out if any one has noticed? Link
edit. I'm 6 hours too late lol
Quad core helps the scores but the 8800GT seems to be massively memory bandwidth throttled - once I got above 700MHz on the core I only saw marginal gains from further upping the core clock unless I also upped the memory clock... and I'm not sure on the wisdom of running an 8800GT at or above 2000MHz on the memory...
With an E6600 @ 3.6gig and an 8800GT running 740/~2400 I hit 14K just - but I don't think the memory really like it as it hard locked soon after.
My 8800GTS 512MB at 800/2000 doesn't go higher than 11.2k at stock its about 10.9k, overclocking the CPU over 3.0Ghz will give me around an extra 2k points.
