sticking a pin in my head.... oopps!
Just HOPE it wasn't a blood vessel. I had a very small one in my back, about the size of a spot. It had to be removed with surgery leaving roughly a 4cm scar.
Well this thread is proof your a wuss, should have just stuck a hyperdermic needle you found laying by the street in it, rubbed the blood over your body and bend some metal!
Alpha!
hmmm nasty, well seems to be looking a lot better, will keep an eye on it and see the doc if need be, i reckon i did the job,
Did it fire out? You could have drawn your name in the mirror or freaked someone out with a bloody hand on the window.
Sounds like a nose bleed.... but on your forehead. I will name it "head bleed"!
At least you didn't put toothpast on it as recommended in other spot thread on here. I still have a red mark on my noose from when i did this on a large spot on my nose a month down the line!
