2 8800GT or 2 8800GTX?
Will there be much difference between these 2 cards in SLI..
Will be playing games @ 11920 x 1200 on a BenQ FP241W...
2 GT > 2 GTX.
You sure, so the 2x 8800 GT's, and the 2x 9600 GT's, beat the 2x GTX's when they have less Memory, smaller Bus's, and less streams.![]()
The 9600GT is only closer to the 8800GT in NV mobo's which you obviously need for SLi, in other mobo's the 9600GT is even slower.
I'd get the cheapest which is 2x 9600GT SLi and the best NV mobo for your cash.
First of all, The OP is talking about SLI and all discussions are based on that.
He has to have a SLI board.
Secondly, do you think 9600GT works much worse on Intel boards? And the gap bettwen 96GT and 88GT would be enlarged on non-NV boards? I've never heard about it. Any proofs would be appreciated.
Thirdly, we have the common sense and the same recommendations to the OP, anyway![]()
I know he's talking about SLi and there is nothing wrong with saying something that is not about SLi.
I have no proof, but there was some articles around here if you look around about NV's trick that boosts its performance, its something to do with PCI-E frequency at the same speed as the core clock, I dont know exactly how it works without reading it, but its along those lines.
 And I think OP is a similar kind of OCer like me
 Linky has been posted in this forum.It's called LinkBoost, and it's been an advertise feature of NV boards for about 1.5 years now.
I'm a heavy overclocker, I push my stuff as far as it will go, well I havent pushed the ram to the max yet, but my CPU is almost to the max and I bios modded my 88GT to get an extra 20Mhz out of it and 50Mhz on the shaders.
Go search for the thing about the trick on the 96GT, it sheds some light on its odd performance.
Ignore spec below.. everything will be new![]()
What is your shaders clocked at on the GT? 8800GT @ 700/1800/1000 here gives me 13296 in 3dmark with a dual at 3.4.
	I can't at all understand how people are claiming two 8800GT's in SLI are faster than two 8800GTX's in SLI?
