- 7 Aug 2004
g effort but as said abit pointless 3dmark isnt really an indication of real world stuff
Why is everyone critiscising it as pointless he spent good time doing this not to have everyone slate it just because 3dmark isnt real world stuff which agreed it isnt but it gives a general idea.
thanks steven
Well i think people have taken my results (which i took my time to do, to help people out) in the wrong way.
i was simply pointing out that in 3D06 the CPU at higher RES doesnt make THAT much difference then it does at LOWER RES.
i will however, if people want me to run the crysis benchmark at the stock and overclocked speeds & to test COD4 would be un-even as it doesnt have an inbuilt benchmark. but i can run it for a few minutes on the same place in the game and record my results (if people are interested)
at the end of the day im going to lose free time and gaming time doing this and if people are going to critisize my results then i may as well not bother.
What i post in this thread is suppose to help people who want higher res monitors and are worrying about CPU limitations so im testing at the highest res i can and the *normal* res at stock and at an overclock of 1.29GHz to provide an example of how the CPU contributes to the game action you will see.
Thanks for Reading all those who found this useful
StevenG
I thought that stevenG's results are perfectly valid, even if it is 3dmark.
Ok it doesnt show exactly real world stuff in how games would react to the CPU change but it shows in a sense that even when the CPU is clocked pretty high from stock, there is a much smaller increase than at the higher res.
Cheers for the info to back up what we were thinking, looking forward to COD4
Hi mate, I'd be interested in some benchmarks that show the LOW fps. Average is meaningless and becomes more meaningless the longer the benchmark is run. Whereas the LOW fps times during the benchmark are whats important and going by those low fps moments alone...the longer the benchmark the better.
Average FPS = total waste of time and demonstrates nothing important![]()
Minimum fps is even more pointless than average, since it may only go anywhere near that low for less than a fraction of a second, so whats your point? that 3dmark should use standard devaition? Theres also the reason that people run 2/3 loops on the crysis benchmark, to give a more realistic result to how it will actually play.
I dont mean to sound mean... but this is very well known stuff. It's been like this since GPU's existed. And SO many sites have done tests like this over the years.
This stuff really should be common sense even, but from reading these forums it isn't to quite a few people. So i hope your results atleast educates some of them.
Do both for good measure, will only take an extra 10 mins.
Do it without AA/AF too.
So the max bandwidth the 8800GTX can handle from a Core 2 would be whatever it is at 3.6Ghz?
That can't be right?
The faster the card the more bandwidth it can handle, So you need a faster CPU to keep feeding it the instructions?
While playing a game you will never notice an average frame-rate of 50fps, but you WILL notice the minimum frame-rate of 20fps...
Please remove cranium from rectum... it may be obvious to you, me, and anyone else who knows their stuff... but in your elitist know-it-all snobbery it may surprise you to know that not not everyone knows this sort of thing, and i'm sure you were once as clueless as any noob.
