PHP: array - for every 4, "do this"?
Hitman
25 Feb 2004
Hi,
Having a bit of a problem. I'm storing a bunch of data and retrieving it with mssql_fetch_array, and outputting it like so:
Code:
(code goes here to retrieve the details)
<table>
while( $row = mssql_fetch_array( $query ) )
	$type = $row["pm_type"];
	$id = $row["pm_id"];
	$name = $row["pm_name"];
	$img = $row["img"];
	$img_full = $row["img"] . "_full";
	$AP = SomeFunction( $type, $id );
	echo "<td>whatever here</td>";
</table>
What I'm trying to do is output 4 results per table, and then make another table if there's already 4 results in the previous table. Obviously with the above code I can't do that because the while puts it all inside one table.
Hope that's clear, and hope someone can help!
Cheers in advanced
How about:
PHP:
<?php
$loopCount = 0;
    if ($loopCount % 4 == 0) {
        if ($loopCount > 0) {
             echo("</table>");
        echo("<table>");
    $img = $row["img"];
    echo "<tr><td>Row ".$loopCount."</td></tr>";
echo("</table>");
I haven't tested this, just written it out whilst copying some data. Beware, i'm tired, so it could completely fall apart. The key bit though is the % sign. This signifies the modulus operator (http://us.php.net/operators.arithmetic). Basically, if the remainder of the loop counter divided by the number of cells you want (4 in this case) is zero, this should start a new table. It should also end the previous table, assuming one has been started (hence the $loopCount > 0 bit).
Hopefully, that will give you some pointers.
Matt
Hi,
Managed to come up with this based on your code, feenster99:
Code:
$loop = 0;
	if( $loop == 4 )
		echo "</table>";
		$loop = 0;
		echo "<table>";
	$loop++;
Yours didn't seem to work properly (excused though considering you were tired :p) but based on yours I've managed to cook that up and seems to work :)
Cheers
Yours will only work once—i.e. after 4 results, not after every 4 results. Change your $loop == 4 to $loop % 4 == 0.
(feenster's didn't work because he never incremented $loopCount, fyi.)
Blah, forgot about incrementing the counter. I tend to use for () {} loops anyway, so that's taken care of. My bad.
Glad to see you found a resolution though.
Matt
Actually it should work properly because he's resetting the counter on every fourth iteration.
