Lian Li PC-A77 Full Tower Case Thread
19 Aug 2005
Ealing, London
This is a case I'm very excited about, the bigger brother to the A16/A17...Looks like Lian-Li's "stacker" with plenty of room for Watercooling.
Casing Dimensions and Specifications
Height: 595mm
Width: 220mm
Depth: 590mm
Weight: 9.5kg (net)
Material: Aluminum chassis
Case Color: Brushed Aluminum Black
Motherboard Support type: Micro, Standard ATX and Extended ATX
Drive Bays and Expansion Slots
12 x 5.25" External Drive Bays (1 x 5.25" to 3.5" Converter with FDD bezel)
9 x 3.5" Internal Drive Bays
Ports
7 Rear Expansion Slots
4 x Front USB2.0 ports
1 x FireWire (IEEE 1394) port
1 x eSATA port
Audio In/Out
Case Cooling
Fans
1 rear 120mm fan
3 x 120mm fans attached to HDD cages
Vents
Bottom meshed intake vent for PSU
Power Supply
None supplied
PSU bay supports Standard ATX PS2
Product Page
First Review: here
Second Review: here
Product shots
I must admit, i doo like the look of that case a lot!
Dual PA120.3's me thinks, one in the roof, one in the front... mmmmm!
Oh and I want one in silver :)
p.s I was looking for a PC-7077 for about 6 months but now i need look no longer...
WOW this looks really good, like the Armorsuit PC-P80 but with a sleeker look :) , wonder how much it is going to be here in the UK cause i am quite tempted :)
Quality Lian Li cases but id still like to see more effort towards Silent Cases or a Eclipse62 clone Lian Li style and im sold once again ;)
The V1100's just been updated as well (the one with the door), that was a very quiet case, I actually found it quieter than the P180, the doors were nice and thick and it was fitted with the sound deadening foam stuff, I just don't like the divider thing across the middle. :)
Me too!
Like you I've got a PC-70. I wanted to update it to a PC-7077 but found they are no longer available so I bought a PC-G70.
The PC-A70 and PC-A71 appear to be updates for the PC-70. The PC-A77 appears to be the update to the PC-7077!
I don't know how someone can justify spending a couple of hundred on just the case. I've never been able to do it. I've spent up to £40 and thats my max. If I was going to spend that much I'd rather do a custom job like the one in my thread!
