Got a new Corsair 620 psu and have connected it up and the 3870x2 is running really slow, like its starved of power.
Have I connected it wrong, have two 8 pin connectors, so have plugged one 8 pin in, then into PSU, then used just the six pins of the other one into the other space in the psu, so hence using two different rail.
Should I have used just one of these black connectors and one of my own 6 pin connectors plugged into a molex off the same rail, hence using only one 12v rail.
The card was fine before on my Antec 550w using a 6 pins connected to seperate molexs.
Thanks for any help
the reason I say its slow is crysis bench is down to 23fps from 46fps.
Thanks for any help
