Upgrading 7800GT
10 Mar 2008
Deklein
Im looking to upgrade my graphics card which is a Nvidia 7800 GT running on a Asus A8N32-SLI Deluxe mobo.
Its been a while since i upgraded, so im out of the loop with what i can and cant fit. The motherboard says it will run Dual x16 PCI-E, so im looking to find out what i can fit from the current Nvidia range.
• Would a 8800 work?
• could i SLI them?
• would i need to update the bios?
thanks for your help.
Hi,
Welcome to the forums.:)
8800 would work
You could SLI them.
A bios update would not go a miss.
Depending on what CPU you have you may find you are cpu limited.
its running on a 20" widescreen so id really like to make use of that in games maybe running at 1680x1050 - my current setup doesnt really allow for that.
It is SLi compat, but it will not be worth it with the cpu limiting it.
You will notice a big difference with buying that gfx card as a singular one though.
