So, a Q9450 at 3.6Ghz would be more like a Q6600 at 3.7Ghz?
Not at all.
Well, come on then, you'll have to give me a bit more than that!!
My E8400 at 3.4ghz was max 5% faster in specific apps and a general PC benchmark (Custom PC) than an identically clocked E4300. Yeah, at super PI the E8400 was much faster, but in general use?
EDIT: For a Q9450 at 3.6Ghz to be like a Q6600 at 4Ghz, it needs to be approx 10% faster clock for clock. That's not the case comparing the Q9450 vs the Q6700 in the table above is it, it's more like 3%?
graysky requested me to run his new X264 benchmark. Thread on XS here. It shows that the Q9450 (2.66Ghz) is equivelent to a Q6600 @ 3Ghz for encoding DVD using next generation codecs.
This Penryn is 2 to 5 hundred mhz faster than a Q6600 clock for clock also using a lot less power making it easier to cool and overclock.
At 3.6ghz a Q9450 is like having a 4ghz Q6600
The SS4 Instruction set of the Q9450 sees huge gains in multimedia tasks.
It will need less vcore so in essence will run cooler.
Not quite, most people who know what they're talking about are saying that SSE4 is practically useless (admittedly I don't have a clue about that).
Also most benchies aren't showing a 10% improvement, its ranging between 2-12%...
Most games are showing ZERO tangible improvement.
You gotta ask yourself why your upgrading?
Firstly (and the main reason really), I do a lot of video encoding. Some times with files as large as 6-8gb in batches. Mostly using tmpenc 4 express which seems to support SSE4.
You come across as a funny so and so sometimes easy!!
Anyway, thanks for the links, but I'm not sure it's as conclusive as your silence hinted at!
The original x264 video encoding link over on XS showed the Yorkfield's being 5 to 6% faster clock for clock than the Q6600. I've already said where an app uses SSE4, the Yorkies will be quicker, no question, but generally I'm not convinced about how much faster overall they are than the Kentsfield chips yet.
I suppose I'm trying to ask are the general performance increase worth the extra outlay? I'm sure once folks on here get them, we'll know, and I hope they do perform as well as we hope. Certainly they should use less power, which is a good thing.
Is this how urban computer myths start - before you know it everybody bandies about the 'fact' that a Yorkfield at 3.6 is 'like having a Q6600 at 4Ghz'. They were saying the same about the E8XXX CPU's, and I know for a fact they weren't, at least in my test system. So, how are the Yorkfields different, apart from the obvious of having two more cores?
I'm going to find out for myself soon enough anyway, as got a Q9300 on order.
One thing I do know for sure though, who's going to be buying a Q6700 when the Q9450 arrives?! The Q6700 never looked the most competitively priced chip, but it looks even worse value now.
Well I know what I am talking about.
Adobe premier for example, The latest version programmed with SS4 instructions see big gains when video editing.
Games will show little gains due to current games being GPU limited not Cpu
limited.
So your last post is a moot.
