Adding option to print server so that logon names are printed
26 May 2006
Edinburgh
I have heard it is possible to have an option enabled so that when documents are printed the users logon name is printed onto the page.
How is this done?
From memory (which isnt that great) the option is called a seperator page. Havnt got time to play with it right now but maybe give it a try, not sure if you will have to setup this on every pc or if you are using a windows server you can set this up their.
Good luck
BS
Normal on the things I've seen, (not Wintel), this is done by enabling banner page printing on the print queue which then prints this sort of information.
