The triplex 3870 I have is about an inch and a half shorter than my 2900 pro was (stock cooler etc on that) as well as they zalman flower type cooler which does a great job.
And does this cooler take up 2 slots?
Is it just a case of editting BIOS to remove that? I'm very interested in trying to get clocks of 1000/2000 now
Few questions (sorry if I'm getting on your nerves!):
Is there any chance you could link me to the site where you got the vmod from?
What BIOS are you currently running now?
What are the performance gains with the core at ~1Ghz albeit with stock mem? Can we get some 3D06 benchies comparing stock and your highest core clock?
Are these cards quite short compared to the normal 3850's?
Because I've volt modded it. I can hit almost 1Ghz, although I'm now limited by OCP since the card shuts down with ~ 1.55v. I'm working on removing that.
It's frustrating having the option to go to 1Ghz on the core, but leave the memory at default (newer BIOS) OR be limited to 860 on the core but go around 1Ghz on the memory (default BIOS).
So you must be water cooling the core then ? and the ram chips as well?
Have you hard modded it to take voltage that high, I have my voltage at 1.4v but I can only get 870mhz or so. Temps arent too high on air so wondering what volts might be safe for it
About the bios, I can alter my core or memory to whatever I like its just the memory must be getting too hot so I cant max that out :/
Its Gecube, have you tried it, maybe I can send a bios dump if you want.
Original owner/modder for this card was 4Qman if you want to check out his thread on it
Can you all do the crysis test so I can compare, 3dmark06 is too cpu biased
Q6600 Fat boy cascade @ 1.7v - Supertalent DDR3 @ 2v,Gecube CROSSFIRE 3850 1.64v GPU,vmem 1.94v.
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 31.9
Play Time: 75.46s, Average FPS: 26.51
Min FPS: 9.99 at frame 890, Max FPS: 36.13 at frame 1766
Average Tri/Sec: 26112288, Tri/Frame: 985182
Recorded/Played Tris ratio: 0.93
!TimeDemo Run 1 Finished.
Play Time: 61.69s, Average FPS: 32.42
Min FPS: 9.99 at frame 890, Max FPS: 40.58 at frame 986
Average Tri/Sec: 32270360, Tri/Frame: 995352
Recorded/Played Tris ratio: 0.92
!TimeDemo Run 2 Finished.
Play Time: 63.73s, Average FPS: 31.38
Average Tri/Sec: 31249626, Tri/Frame: 995803
No idea about the bios, I dont flash stuff often but thats what tray tools dumped out. Any other programs I can use?
Are you using this BIOS on your Triplex 3850?
You could use ATIFlash, but only from a pure DOS prompt - boot from CD / USB / floppy.
I tried defeating the OCP and failed. The card still works though.
I'm limited to 1.5v which is a shame = 972Mhz GPU.
Unless I can get another BIOS, the memory is limited to 783Mhz without artifacts!
