What sort of Mileage is it worthwhile getting a Diesel?
glad you like it, i'd of gone for the 3 door myself and a high milage 1.6 tdci to remap it (regardless of milage per year) it's much better then the old gutless petrols
The new petrols are hardly any better, they're only gutless if you stay below 3.5k :)
One thing I have noticed with the interior.. where the hell does the passenger side airbag come out of? theres no seperations along the top of the glovebox?
New/recent transit range.
The ones ive driven havent had nice interiors, its all hard wash down plastics, perfectly suited to most van uses where they will get cruddy, but not "nice".
Haven't Ford vans always had similar interior to the car models anyway :confused:
The term nice was meant to be used loosely.
its got a weak spot built into the dash so the air bag can just explode out, downside is that if you prang it you will need a whole new dash board
Why is it called a Zetec Climate if it doesn't have climate control? That's as bad as the Focus MP3 that doesn't have an MP3 compatible stereo!
