Anything to match Lian Li PC-A71
5 Aug 2006
Hi there,
Just curious. Is there any case that is as mu-hassive as the Lian Li PC-A71. I hate small cases with a vegance, cable management and neatness is just so much easier in a big case.
The only thing that comes close I know of is the Eclipse. But I much preffer the look of the A71. Just it costs and arm and a leg, and another arm and maybe another leg! :eek:
ta
alec
Mozart is just a big case, the actual area you get to work with (around the motherboard I mean) is not a lot bigger than any other case to be honest.
By big I mean the size of the PC-A71, maybe a tad bigger if the case is fantastic in every possible way.
Again the area around the motherboard itself isn't that big. I'm not looking to house lots of hard drives or anything just something I can keep neat and isn't crampt and hot.
Good call though. But I've been looking around and I think im pretty much set on the PC-A71. Anyway - Wont get one for a while yet so maybe something else will show up in the mean time :)
The Lian-Li A77 looks superb as does the PCV2110. If you want something cheaper the old shape Stackers are certainly roomy.
My G70 is massive. Its discontinued but the price OC have it at the moment it is a steal. Try searching google for it and they go for around ~£170 elsewhere.
Doesn't come with a removable motherboard. Doesn't need to as the space around the motherboard is phenomenal and I suppose cable management isn't as good as newer cases.
What about the pca-10b?. This can be purchased cheaper elsewhere.
Dont fancy the look of the G70, but like you said couldn't believe price when I saw it.
And PC-A10b is just baby/older version of the 71 so sod that ;)
Im gonna go for it - Just as soon as I get paid. :cool:
Had a A-71, didn't like it. Felt a bit cramped when working and was too big for the room I was in.
The motherboard tray slides and then lifts out from the bottom, which causes a bit of trouble if you have a decently sized cooler.
