- 5 Mar 2008
- London
Currently i am building a budget gaming pc, and to increase the amount of money spent on components, i am going to stick with my current case.
The case is an atx case, and all it has as far as cooling goes is two (i think 80mm) fan grills on the back.
Unfortunately unless i have a real overheating problem the case will need to be enclosed in a small space, there is a small amount of room at the sides,top, and the front and back will be left clear.
the system will be somewhere on the lines of a q6600,8800gt. with an ak-965 cooler.
What alterations to the case would you advise?
From speaking to a few friends, they say that one of the best methods is to add an exhaust in the top of the case is this a good idea?
Should it be near the front or the back?
should i make some big holes in the side of the case to add fans?
Which should be exhaust and intake? what size fans should i use?
and should i remove the fan grills at the back to improve the air flow? (they are quite bulky)
thanks for any help!
