Arch linux - working packman repo
7 Jan 2007
Sussex, UK
lo,
Finally after 4 hours got my ethernet card to ping google.co.uk :)
but now the bloody pacman repo dont work, can anyone link me to a working repo and how do I add it to my list and remove the old one via the terminal?
Look in /etc/pacman.d/ depending on the pacman version installed there will either be one mirrorlist file or 3 file core, extra and community. The default mirror is an official arch one which is capped which is probably why it wont work for you.
These files have a lot of different mirrors in, so just edit them (with nano or vi) and disable the ones that are not working for you by preceding the line with a #.
sorted I think, well its downloading 140mb worth of updates at a reasonable pace.
Its downloading a new kernel, hope its reboots :S
Just realised that Arch is a rolling release! Thats well good, hated having to re-format and re-install ubuntu every 6 months.
Really hope I can get Arch up and running.
Wouldn't worry about the new kernel not booting - it's almost guaranteed if the previous kernel worked.
Arch is pretty easy to set up and configure (once you're used to it, you can build a full system in less than an hour - easy)... The Arch wiki is good, and a fair proportion of the guys on here use Arch as well - so any probs, just ask :)
I ran the command pacman -Syu it downloaded a new kernel and I rebooted, how do i check I have the new kernel?
I only ask as my grub menu aint changed. In ubuntu it would take an hour to install a new kernel and arch as super quick, is it vos i dont have a gui yet?
Sorry a n00b
If you're using the default kernel, Arch updates menu.lst automagically.
To prove the new kernel is running, use
Code:
$ uname -a
Which will tell you (amongst other things) the kernel name.
poo. sorry - was expecting a little more detail than that!!
Both
Code:
cat /proc/version
and
Code:
uname -a
will tell you the kernel major and minor versions - however obviously doesn't tell us distro specific versions.
Code:
pacman -Qs kernel
will tell you the currently installed (distro specific) kernel.
Found out it was the latest kernel, im now posting from my Arch Linux install :)
Gonna have to do it again, as I rushed through it and stuffed up my users and groups, along with not configuring sound :p
Is it normal to only have system > administration > login window only along that tab? Think its cos I haven't setup the groups properly.
Now gonna have a play with pacman and next week i'll try to get a proper arch install going.
Kudos :)
Nah - no need to reinstall just for that - just add your user to the correct groups - I tend to use
Code:
# gpasswd -a <user> <group>
... but really, you can use any of the various other commands for this. Top tip - add your user to storage and optical if you want to be able to use usb drives and burn cds/dvds.
Not sure what you mean by this.
Code:
$ man pacman
A command that will tell you quite a lot :)
lol its totally "ballsed" up now, got tired and grumpy last night and skipped a few pages relating to sound setup, user accounts and adding gnome to boot and stuff.
I'm an idiot. At least I know that I can do it now, with some more time and no interuptions at home I can get it working.
Gonna start it again Thursday night and finish it properly Friday.
The bit I find confusing is the users and groups setup. I am gonna have to gooogle for a better tutorial.
Thanks for all your help guys, I'm so close!
Could be worse (better?) - my last Arch box didn't recognise the sound card, so I went down the custom kernel route. That was quite a while back (noodle, I think). I learned a lot though.
yeh my first "half arsed" attempted at a "mans linux distro" went well, I learnt more terminal commands, i learnt how to edit in nano.
I must say I think Arch will be easier in the long run, obviously the initial setup for a relative beginner like me is a little tricky but pacman -Syu will mean less annoyance in the future.
pah, real men use vi
I couldnt work out vi at all lol nano just worked. I have to use it though as part of the tutorial I was using.
Whats the key combo to save?
If your in insert mode then key combo to save is esc :w
:wq to write and quit, :wq! to write, quit and force it.
vi > emacs by far :)
