I've been doing some reading on the net, apparently there are some subtle differences when this is done, so I'd like to do it. I also think it's a good excuse to buy some decent speaker cable and not the generic stuff I have, which came from the shop.
Just wanted to ask if people have any preferences and things to stay away from. For example, is flat speaker cable good? Or is it more for tidyness than quality?
Are QED the best manufacturer? One thing I noticed is that most of the QED speaker cables come with the bannana plugs on the end. I do not need any connection as it just has the screw type connection on the speakers and amp. Would I be ok, if I were to buy QED cable, to chop these connectors off?
I'm looking at a total of 6m. (2x2m for one speaker and 2x1m for the other). As the right-hand speaker is closer to the amp.
Also, what is the difference in the mm2 size? i.e. 1.5 / 2.5 / 4.0 mm2
The cable I have at the moment seems pretty thick... is that better?
So please, any tips, info or advice much appreciated.
Cheers!
  Very helpful stuff.  Thanks for the links also, will have a read of them.
