- 17 Dec 2004
- Crawley, WEST SUSSEX
Hi,
Ok I have an old Vauxhall Carlton J reg and unfortunately there are 2 small cracks in the plastic header on the radiator. Now I tried a bit of DIY as I couldn't find a cheap radiator and a new one is £100+ so thought I would try 2 part epoxy resin. And it did work for a time but the heat has just degraded the epoxy, so I am wondering if any of you know where I can buy some epoxy that has a high temperature resistance?
Ta
Ta
