As a few of you may know i recently bought a Pug 406 for running around in and for work, cambelt snaps on way home so after much debating what to do with the car it's decided to strip cylinder head down & rebuild it.
It's just taken the best part of 2 days free time to seperate the bloody exhaust manifold from the downpipe so that we could get the head off due to the bolts being in the most stupid place ever AND rusted solid, and the fact that they put one end in a recess you cant get a ring spanner into but cant get a socket into it either as theres no space for one!
ARGH!
Why not have one end in a hexagon shaped hole rather than a round one so you dont have to get two arms down the back of the engine block which is about 2 inches from the bulkhead!!!?!?!
My dad just spent a good hour under the car with half a saw blade gradually cutting the bolt off.
I'd start on the haynes manuals too which tell you to take out bolts that dont exist but that would double the post length!
Still, should be back on the road within a week for less than £100 repair costs, not bad for a snapped cam belt
ARGH!
