Lowest price in the UK - OcUK GeForce 9800 GX2 1024MB GDDR3 @ £352.49 Inc. VAT!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK leads from the front by not only bringing you the latest product first but also the lowest price on the latest and best:-
OcUK GeForce 9800 GX2 1024MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Beautifully designed and engineered for extreme power, the OcUK NVIDIA® GeForce® 9800 GX2 1GB graphics card is The Console Within - a complete, high definition entertainment and gaming solution for the PC. With NVIDIA HybridPower™ technology and two on-board GPU's, the OcUK NVIDIA® GeForce® 9800 GX2 is bar-none the fastest graphics card available and up to 50% faster than GeForce® 8800 Ultra. When paired with an additional OcUK NVIDIA® GeForce® 9800 GX2-based graphics card and an NVIDIA nForce® 7 Series motherboard, this Quad NVIDIA SLI® technology solution creates the most awe-inspiring, screaming fast gaming platform to date. Be blown away by scorching frame rates, true-to-life extreme HD gaming, a picture-perfect HD DVD and Blu-ray Disc® movies with ultra-smooth playback.
- GeForce 9800 GX2 core running at 600MHz
- Shader Clock Speed of 1500MHz
- 1024MB GDDR3 Memory running at 2000MHz
- 512-Bit Memory Interface
- 256 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 76.8 billion/sec
- Memory Bandwidth: 128GB/s
- Up to 50% faster than GeForceR 8800 Ultra
- Display Connectors: 2 Dual-Link DVI-I, HDMIR Out
- HDCP Capable, HDMIR Capable
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- 1yr Warranty with OcUK
Note: This card is 295mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 600W minimum for PSU and 700W+ is recommended.
Price: £299.99+VAT (£352.49 inc VAT)
BUY NOW!!
Now thats a good price for the card. Not much more than the X2 when it was first released. Good work Gibbo! :D:D
how do i fit one of these with a corsair 520w ? I dont really want to start filing off bits of plastic off the connector....
And will it fit in an antec 900 as it was a tight fit with an 8800 GTX...
It still costs too much... :o
Only joking, good price for these - however i'm happy with the X2 :)
To be honest I'm sure they are but it's a lesson learned really. It never pays to be an early adopter.
You just get bent over, I know as I've been there many times through my computer building years :)
