Probably quite a comparison here, but im looking to upgrade my whole rig since ive not done so for over two years. Im currently using an ATI X1900 XTX which has served me very well, but someone has made me a nice offer for my whole system, hense the upgrade.
I've been shopping around and ive pretty much narrowed it down to buying a whole PC, specifically one of the Dell XPS machines (Im using one at work).
This is the first time ive bought a full system, but I think its incredible value for money with very good specs.
My choices are as follows:
*XPS from Overclockers with the 8800 GTX (£1000 inc)
*XPS From Dell (the cheaper machine without a decent card, @ £600) and purchase either a ATI 3870 X2 for under £300 and have a full system for £900
*Or wait just that little bit longer for the higher spec 9800 range to come out and see if its either slipped into an overclockers/dell deal, if not consider it on its own.
Whats peoples opinions/suggestions?
The obvious thing that stands out to me is the difference between core clock speeds, the ATIs running at 825mhz and the nvidias at 600mhz.
Theres also a significant price difference between the two, do you think it warrants it?
