**** The Lian Li V1000Z ****
4 Mar 2003
Herefordshire
Looks like it has a built in PCB so the HDs plug in like hot swap bays, full mesh bay covers (usually 5-6 quid a piece), simple built in fan controller, cable routing holes in the motherboard tray, PSU is held partially outside the case to make more space, 140mm side panel fan, holes for water cooling tubing, more I/O ports...
Looks bloody brilliant :D
:p
Few images ive found:
http://www.lianlimodding.com/cebit08/cebit08-10.jpg
http://www.lianlimodding.com/forum/attachment.php?attachmentid=1110&stc=1
That looks amazing. The hot swap HDD bay is a stroke of genius. I assume there's some standard connection dimensions, so all SATA drives will work?
I really want one...:)
I want one too...shame it'll cost more than I can afford. :(
Yeah, if you go through the pics on the LL site, you'll see that the power and data connections for the sata drives. These positions seem to be standard now. :)
InvG
Wow that looks fantastic.
I'll presume you can have a normal bracket for the powersupply so it sits properly inside?
That case has everything I like about the V series, yet none of the downsides as far as I can see.
I hunted high and low for mesh bezels for my V1000 +II last autumn, and ended up getting the EX33 3 HDD mesh fronted bay. The bezels are widely available now though! The new ones seem to have filters on.
Nice case but i`m gonna try and hold out for the PC-V1010
Just one problem maybe I can see is that it could benfit from another intake fan at the top, doesn't look like theres much room for air to get to the motherboard from that bottom intake fan
Naud
I think the fan over the graphics card would be an intake.
Plus the whole case is vented so don't think it would be much of a problem.
