I have four different types of CF card. I have been doing a little experiment to see what difference the card make to the performance of the camera.
I used Audacity to record the sound of the shutter and took measurements from the soundwave trace afterwards. I'm shooting raw, without noise reduction.
With all cards, I got a similar pattern:
- 10 or 11 frames at exactly 5 fps.
- A pause
- 2 more frames
- A pause
- 2 more frames
- A pause
- 2 more frames
- etc...
The first pause was short.
The second and subsequent pauses were longer but all the same length
The result were not always consistant. Sometimes a burst of 10, sometimes a burst of 11. Most of the subsequent pauses were the same but occasionaly there would be an irregular, longer pause. I report below the most consistant results:
Sandisk Ultra II:
first pause: 2.9 Seconds
subsequent pauses: 5.9 seconds
Sandisk Extreme III:
first pause: 1.7 Seconds
subsequent pauses: 3.1 seconds
Sandisk Extreme IV:
first pause: 1.8 Seconds
subsequent pauses: 1.9 seconds
I also have an own-brand card from a dealer near Euston:
first pause: 2.2 Seconds
subsequent pauses: 4.2 seconds
So, the speed of the card does make a difference, but of course, only after you have filled the buffer. Clearly the 1DsMkIII can take advantage of the improved speed of the Extreme IV. It's a shame the that the only one I've got is only 2Gb. At 25MB ech, it only takes around 80 frames...
Andrew
- A pause
- 2 more frames
- A pause
- 2 more frames
- A pause
- 2 more frames
- etc...
Sandisk Ultra II:
Sandisk Extreme IV:
Andrew
